Cooler Master Elite 120 Advanced
R7 3700X | X570 Aorus Master | 32GB | EVGA 1080 Ti FTW3 | Noctua NH-D15S | FD Meshify C Copper
R7 1700 | X370 Gaming-ITX | 16GB | RX Vega 64 LE | Noctua U12S | Node 304
2 x HPE ProLiant Microserver Gen 8 | 1265L V2 | 16GB | 20TB
GTX 260 SC | GTX 280 SLI | GTX 280 Tri SLi | GTX 590 Quad SLi | GTX 980 ti | RTX 2080 Ti Strix OC | RTX 3090 Strix OC | RTX 4090 Strix OC
The Way It's Meant to be Played|NVIDIA
ASUS MAXIMUS Z790 APEX Encore | i9-14900KS (delidded/direct-die) | 2x24GB G.Skill 8000 M-die | Corsair AX1600i | Samsung 990 PRO 4TB | Corsair 7000D Airflow | 15x Corsair ML Pros (8x ML120 Pro, 7x ML140 Pro) | Rads 360+360+420 | LG C3 48" 120Hz
"Du vet väl att fildelning är förbjudet! Köp en till frugan också"
*-<|:C-<-<
Nytt namn, samma bismak.
CITERA FÖR SVAR! :)
Falling In Reverse - Game Over
"Midway upon the journey of our life I found myself within a forest dark, For the straightforward pathway had been lost."
My rig 144hz 1440p 27" samsung g5, xfx 6950xt, 11900K, TM Peerless assassin,Gigabyte z590 UD, 32GB 3200MHz Vengeance, 1tb nv2, 2TB SSD 4TB HDD, corsair750 vengeance, Lancool 215.
GFs rig 144Hz samsung 1080p, Palit 3060Ti, 10400F,corsair H60 , B560 Auros, 16GB 3000MHz, 500GB NV1, 480GB A400, 2TB+750GB HDD, Seasonic 650 gold, Kolink Void Laptop Lenovo Legion 5, 2060, 4800H, 16GB, 1,5TB NVME HTPC 3060, 10400F, 16GB, 500GB NVME, 960GB A400 3rd PC 3060Ti, 3700X, Hyper 212, 16GB, 250GB SSD, 2TB HDD, 650w gold, P300A
(PC): i7 4790k 8gb ram Asus380x 256gb ssd
(Laptop): Dell xps 13 i7-8550u 8Gb
|ASUS Z170-A||6700K@4.6Ghz||Corsair H50 Scythe GT 1450RPM PnP||16GB Crucial DDR4 2133Mhz@2800Mhz||MSI RTX 3070||Crucial P3 2TB||Corsair HX 1050W||Fractal Design - Define R2 Black Pearl|Citera för svar
Fotoblogg: PlanetStockholm
Why procastinate now when I can do it tomorrow?
MAIN: | 4770k | r9 290 tri-x OC | 16GB | Be Quiet Shadow Rock 2 | Corsair 350D | EVGA Supernova G2 850w |
HTPC: | 4360 | 8GB | Scythe Shuriken Rev. B | Cooler Master Elite 120 |
Laptop: HP spectre x360
HTPC Lian Li PC-A05FNB | Intel Core i5-13400 | 32 GB DDR5-6000 | 4,5 TB SSD | RTX 4070 12 GB
Laptop Razer Blade 15 Base 2021 | Intel Core i7-10750H | 16 GB DDR4-2933 | 1,5 TB SSD | RTX 3070 8 GB
Laptop Lenovo ThinkPad E585 | AMD Ryzen 5 2500U | 16 GB DDR4-2400 | 756 GB SSD | Radeon Vega 8
Köpe utav ljudkort? ODAC+O2 COMBO ELLER ASUS XONAR STX
Köpe utav headset? Headsets är skräp, köp hörlur och mic separat.
