Nytt i forumet
Senaste privatannonserna
| 2012-04-30, 18:24 | #1 |
flixxerMedlem Registrerad: apr 2012 |
WD problem formatering
När jag pluggade in min Western Digital externa hårddisk så ville den att jag skulle formatera om den, då gjorde jag en "snabb formatering" och då gick den från att vara 2TB stor till ca 900GB. Hur kan man lösa det problemet någon som har eller har haft samma problem?
| 2012-04-30, 19:47 | #2 |
testade
I am not going to try it on my external drive, but I looked up the tools that in windows 7, and here is what I think you need to do. The (maybe) bad news is that you will lose all data on the drive. The good news is that even if something goes wrong, we can just try a different route without hurting anything.
OK. So the easiest way to get to the tool you need is to go to the start menu and, in the search bar at the bottom, type in 'disk management'. The first thing which comes up should be a utility which is called "create and format hard disk partitions". Click on this, and it should bring up a window which says "loading disk configuration information". When it is done gathering this information, it will show a display with all of the drives connected to your computer. Carefully identify the one you want; you are actually pretty safe since I think that you will only your primary drive, the one you want to format, and a CD drive. It won't allow you to format your primary partition on your main drive, you most likely can't format what's in your CD drive, which leaves only the one you want available for formatting. Still, identify it positively before doing anything to it. When you have identified it, right-click on each partition on the drive and "delete volume". If this option is grayed out, you are probably trying to delete something on your main drive. Once you have deleted all partitions, right click on the empty space created and tell it to do a format. If given the option, do a full format and format the drive as NTFS. You will be able to name the drive, and when it is done you should have a full sized and fully functional drive. The one thing to watch out for is NEVER turn off the power on a drive which is formatting - this is the one thing which I have heard will probably damage a drive. Best not to take chances. Like I said, I'm not testing the steps myself right now, so something may not work. If this is the case or if I wasn't clear on a point, just post and I'll try to sort it out. Och nu hittar jag inte den externa hårddisken help please
| 2012-04-30, 21:24 | #3 |
KlappaMedlem Plats: Örebro Registrerad: jan 2008 |
Högerklicka igen på den externa disken i disk management och välj "skapa partition". Klart!
Intel Core 2 Quad Q6600 2,4GHz@3,4GHz | Noctua NH-U12F |MSI P35 Neo2-FIR | 4x2gb OCZ SLI-Ready Edition XTC DDR2 PC6400 | Gigabyte HD6850 1024mb | Lian Li PC-A71B | Super Flower SF-500P14FG Platinum Certification Passive | Dell UltraSharp 2407WFP-HC | 2x Western Digital Green 64MB 2000GB | Samsung 840 Pro 256GB | Plextor PX-760SA | Windows 8 Pro x64 |
