Fujitsu 27'' SL27T-1LED Wide TFT LED Black
Skånesfagerhult
Aug 2010
Hej.
Letar efter en ny skärm Cdon har denna för ca 2000:-
Något ni ser är direkt fel på den?
Ska främst lira mmo och fps.
Technical details
Special features
LED backlit panel, 6 + 1 touch sensor keys, ECO Status LED: 3 colors for 3 modes, keep aspect ratio option
Stand details
Stand removable
Picture height over desk (min) 79.5 mm
Tilt angle - 5° / + 15°
Picture performance
Contrast - typical 1000:1
Contrast - advanced 5,000,000:1
Response time typical 5 ms
Response time gray to gray typical 3 ms
Viewing angle (h/v) - typical 176°/170°
Color performance 16.7 million colors (Hi-FRC)
Brightness - typical 250 cd/m²
Size and resolution
Aspect ratio 16:9
Diagonal Size 68.6 cm (27-inch)
Resolution (native) 1920 x 1080 pixel (recommended)
Resolution (interpolated) 1680 x 1050 pixel, 1440 x 900 pixel, 1366 x 768 pixel, 1280 x 1024 pixel, 1280 x 720 pixel, 1024 x 768 pixel, 800 x
600 pixel, 720 x 400 pixel, 640 x 480 pixel
Video modes 1080i/p, 720i/p, 576i/p, 480i/p
Picture size 597.9 x 336.3 mm
Pixel Pitch 0.311 mm
Frequencies
Horizontal analog 31 kHz to 82 kHz
Horizontal digital 15 kHz to 82 kHz
Vertical 56 - 76 Hz
Frequencies - bandwidth 225 MHz
Connectivity
HDMI 2 x HDMI
VGA/D-SUB 1 x D-SUB
Audio signal output S/PDIF (optical)
Audio signal input 3.5 mm stereo phone jack
Audio sound output 2 x 3 W
HDMI audio Yes
OSD Languages and setting options
Languages Arabic, Czech, Danish, Dutch, English, Finnish, French, German, Italian, Japanese, Norwegian, Polish, Portuguese,
Russian, Spanish, Swedish, Turkish
Brightness / Contrast Brightness, Contrast, Black level, Auto level
Color 6500K, 7500K, 9300K, Native, sRGB, Custom Color
Image adjust H-Position, V-Position, Sharpness, Clock, Phase
Audio Mute, Volume
Information Resolution/mode, Signal input
Power consumption (typical, w/o sound)
Soft switch off 0.33 W
Power save mode 0.37 W
Operating with EPA settings 29.2 W
Operating maximum brightness 40 W
Data Sheet Fujitsu SL27T-1 LED Display
Page 3 / 4 http://ts.fujitsu.com/displays
Electrical values
Rated voltage range 100 V - 240 V
Rated frequency range 50 Hz - 60 Hz
Protection class 1
Compliance
Europe CE, TCO Displays 5.0, RoHS, WEEE, IT-Eco-Declaration
Russia GOST
USA/Canada FCC Class B, cUL
Saudi Arabia SASO
Global ENERGY STAR® 5.0, ISO9241-307 (Pixel fault class I)
Compliance link https://sp.ts.fujitsu.com/sites/certificates/default.aspx
Quality and Reliability
MTBF (demonstrated) 50.000 h
Dimensions / Weight / Environmental
Dimension without stand (W x D x H) 642 x 67 x 391.3 mm
Dimension with stand (W x D x H) 642 x 209.9 x 437.9 mm
Weight (packed) 7.66 kg
Weight (unpacked) 6.2 kg
Operating ambient temperature 5 - 40°C
Dec 2011
Inget fel på den, kampanjpris bara. På andra ställen kostar den uppemot 3000 så det är bara att slå till, jag ska själv köpa den. Kanske borde köpa in ett par nya armar också för man lär få sitta en bit ifrån haha..
Mariestad
Aug 2006
Är inne på att köpa denna skärm, ingen som har provat den eller så?
Hur är det att köra 1920 x 1080 på 27" 16:9
Har innan en Samsung syncmaster 2443BW 24" med 16:10
Skillnad?
Enköping
Okt 2007
tjena
Har någon erfarenhet av denna skärm? Tack
Antec P190...Q6600@3,4 (1,45V)...Noctua NH-C12P...GTX 280...GA-X38-DQ6...Corsair Dominator 8500 2x1Gb@1133...HPw2207h...3Dmark06 15944p
Lund
Okt 2010
Om du vill ha TN-panel och 1080p på 27" så visst, men den är ju bara stor och billig, förvänta dig inte någon superbild. Enligt mig bättre att lägga till lite och köpa en u2412m i så fall
NAD T787 | B&W CM10S2, CMC2S2, DB1
Enköping
Okt 2007
Ja men det var 27" jag var ute efter. Tänkte egentligen prisklassen 3000:-
Det går att returnera vid postorder!
Mar 2003
Kolla tester här prad.de
