Huawei e398 external antenna Telenor help
Jun 2012
Hi,
I'm trying to put the interwebz in at the summer stugan. Just bought service from Telenor today. Cranked 80Mbit/s south of G'burg. Nice! Drove to the summer house (beaches near Halmstad), and I'm getting 64% 4G signal and less than 2Mbit/s. Connected the Poynting 4g Riktantenn (bought at Kjell) to either external antenna socket on the Huawei and I see no difference. I've moved the antenna all over, no dice. No difference.
What am I missing?
I can read Swedish, so all replies appreciated!
I should add that there wasn't anything besides a 'quick start' pamphlet with the modem, and Huawei's site has no support docs for the e398.
Östergötland
Mar 2011
Vad jag förstått måste man vara väldigt exakt i hur man riktar antennen.
Den ska vara riktad rakt mot den närmsta mast, som i detta fallet har 4G.
Om du vet var riktningen på den masten är och det inte finns en massa berg, skog eller bebyggelse ivägen, så borde du kunna få bättre..
Om du inte vet var masten finns, så kanske Telenor kan vara behjälpliga och tala om det..
Hemma hos mig är det numera en Microsoft-fri miljö..
Dator 1: iMac 27" 5K - i7 4GHz - 32GB 2133MHz - 512GB SSD - AMD 395X 4GB - 2xDell P2715Q 4K - 4TB Lacie D2 Thunderbolt
Bärbar 1: MacBook PRO 13" 2017 / 256GB SSD NAS: Synology DS415+ 16TB
Jun 2012
One would think they (Telenor) would identify the locations of their towers but I've not yet found this info. I guess I'll be asking them.
