Stulna spelkonton och elak kod ett problem för datorspelare
We are the Microsoft. Resistance is futile. You will be bluescreened!
Keytronic for keyboard!
Sanningen måste döljas!
I am Extrazz.
| Gentoo & Win XP | AMD Athlon xp 2,5k+ | 2x 256 ddr sdram, 333 mhz Twinmos standard | epox 8rda+ | club 3d 9600pro | 80 maxtor + 2*250GB samsung | Antec Sonata | Macbook alu
Dator - Dell Alienware Oled AW3423DW, Phantek Enthoo Pro, Intel i7 8700K, Noctua NH-14, Asus TUF Z370-PRO, Samsung SSD 840 Pro 128GB, 32 GB DDR4, Gigabyte Geforce GTX 1080 Ti, 2st x 3 TB WD RED, Logitech MX518, Sennheiser Momentum, Qpad Pro MK80.
Intel Core i7 3770K@3.5, ASUS P8Z77V-DELUXE, 16GB RAM, GeForce GTX 660 Ti, ASUS XONAR ESSENCE STX, SAMSUNG 830 256GB SSD, 5x Samsung HD204UI, 4x WD40EFRX, 1x Western Digital Caviar Green WD20EARX, 1x Samsung HD103UJ, Windows 8.1 Pro
Riggen:ASRock X570M Pro4 - AMD Ryzen 7 3700X - Corsair 32GB DDR4 3200MHz - Corsair MP510 960Gb NVME - EVGA 1080ti SC2 - 3x Samsung 840 500GB - EVGA SuperNOVA G1+ 650W - Fractal Design Meshify C Mini Dark TG
NAS: FreeNAS @ HP Proliant MicroServer Gen 8 - Xeon E3-1230 V2 - 16Gb Kingston ECC RAM - Intel 530 120Gb - IBM m1015/LSI 9220-8i - 4x WD Red 3Tb
Memento mori...
iMac 27" | Mid 2010 | Core i7 2.93Ghz | 20 GB | HD5850 M | Samsung 840 500 GB | 4 TB WD
MacBook Air 11" | Mid 2012 | Core i7 2.0 Ghz | 8 GB | 256 GB SSD
Citera gärna om du svarar på mina inlägg, så hittar jag tillbaka igen! :)
AMD64 & Intel Core 2 Duo
AMD Ryzen 5 7600X, ASUS TUF B650-Plus wifi, Kingston Fury Beast 32GB 6000Mhz CL30, Kingston KC3000 2TB, Sapphire 7800 XT Pulse, Peerless Assassin 120, DarkPower 630W, Benq XL2411T + DELL U2312HM, Phanteks Eclipse P400S
Et ipsa scientia potestas est
(För övrigt anser jag att upplösningen 1366x768 ska dö)
-|| Titan ! :P ||-
1: 3600x-16GB-1070ti
2: 1600x-16GB-580x
3: fx8350-16GB-1050ti
CachyOs. MSI MPG Z490 GAMING PLUS// Intel Core i5-10600K@4800Mhz// Radeon rx 6800 16gb // Corsair VENGEANCE LPX 32GB.
Intel Core i7 965 EE @ 4 GHz
Foxconn BloodRage X58
ATI HD 4870 + Accelero S1 Rev2 + 2st Zalman 120mm
Maskin: i7, 32GB ram, Nvidia GTX 1080, Samsung SSD, XFX 850W, 2 x Acer 22" + Acer 27" XB271HUBM
OS: Win10 64bit
Asrock X58 Extreme III | Intel Core i7 950 + Thermalright Ultima-90I | GTX 580 | 6GB DDR3 Corsair XMS3 | OCZ Vertex II SSD 120GB x 2 @RAID0 |
Arch | 1440p 165Hz IPS | 7800X3D | 1080ti | 64GB@6GHz | SN850 2TB
Senast redigerat
