Water Cooling Help In Sweden
Hey guys I currently live in Sweden and am looking to mod my system. I have built a pc with these specs
Asus rampage 4 extreme (changing to black edition in a month!!!!)
i7 3930k
16gig kingston beast memory 2400
2x kingston hyper x 128gig ssd's in raid
1 ocz vector 4 ssd 250
1 3tb back up disk
680SLI with 4gig ram
ocz 1250watt gold
Cosmos ultra tower 2
I am looking to do a really proper and well done water cooling build. I was wondering what homepages do you in Sweden order from that is trust worthy. I dont want to go to webhallen or komplett since all they will do is recommend a h100i which i currently have until my new motherboard comes in next month. I really need help finding a reliable site that you guys use to order pump/res/rads and all the other extra stuff. Please let me know!
I've read that http://www.coolingstuff.se/ is good. Dont know if their inventory can compete with other international sites.
Citera för svar :)
-> I7-4790K@4,6ghz & GTX 980TI@1430mhz AMP EXTREME <-
Inet has been "Computer store of the year" som years in row now and have a pretty good inventory.
I've been shopping from coolerkit.se lots of times without problems. I can highly recommend it.
Well we Swede's actually seem to be ordering w-c parts from other countrys more often than not but I recommend "Coolingstuff" and if You live near an "Inet" store they do also have the most common parts but not always for the best prices:)
Falling In Reverse - Game Over
"Midway upon the journey of our life I found myself within a forest dark, For the straightforward pathway had been lost."
I've ordered watercooling parts from coolingstuff.se, coolerkit.se and watercoolinguk.co.uk
Can recommend all of them! And I've heard a lot of recommendations about aquatuning.se
Main. - Fractal Design Meshify C - Corsair AX860 - Asus Strix B550-E - AMD Ryzen 5 3600 - 32gb Corsair Vengeance 3200mhz - Asus Strix GTX 1080 - Samsung 970 Evo 250gb - Kingston A200 1tb - 1x 840 Pro 256GB - 2x 850 Pro 256GB - 2x 840 Evo 250GB RAID0 - 2x Samsung 850 Evo 500GB - Logitech G502 - Corsair K95 RGB - BenQ XL2420T - Sennheiser Game One
2018 Macbook Pro 13" 2018 iPad Pro 12,9"
Projekt 13 - Bygglogg WIP
Specialtech.co.uk
*fast delivery
*better prices than in sweden
*large range of products
Aquatuning. Everything you need and little more.
Cooling
Thanks guys!!!! was awesome to get so much feed back and so quick. Really helps that I know I can trust these sites.... Another question, can anyone reccomend a good pump to what im going for without it sounding like a ferrari is starting in my chasis ??? ALSO what exactly do i need to get my 680 4gig ram graphic card properly cooled.... Like does a full cover do the trick or i need to order a back plate too ? sorry I am very new to water cooling. Have a guy who will do it for me but would like to be able to look around first before i go spend that nice chunk of change on my system
I recommend coolingstuff and highflow.nl
Meshilicious, Amd 7950X3D, Asus X670E-I ,64 GB DDR5 6000,RTX4090 FE, Corsair 2TB m.2 / 4TB, Samsung 49" Odyssey 240hz Mini led
thank you!
Skrivet av MackinMike:
thank you!
Backplate help at the most 1-2 degress get a fullcover black and if you want for the looks a backplate.
I recommend that you go on the dcp 655 pump since it got adjustable rpm.
I recommend aquatuning.se. Pretty fast shipping from germany and there's loads of things to buy. And the support is also pretty good!
Tubing
How does it sound combination wise with the black edition rampage 4 extreme mother board and my 680 asus 4gigram sli cards. Red tubes and black mother board sound pretty clean ?
Har en udda fråga, en polare till mig i USA erbjöd mig att köpa en sprillans ny Sony Z1 mobil. Har jobbar i en butik i florida. MEN jag undrar om det kommer att kunna gå att använda i sve???
I'd suggest calling Sony to ask themselves if they use different bands in the US than we do here.
..:: trickeh2k ::..
Windows 11 Pro - i7 8700k (delid) @ 5Ghz - ASUS Prime Z370-A - 16GB G.Skill Trident Z DDR4 CL14 3000Mhz - Corsair AX860i - EVGA RTX 3080 FTW3 Ultra - Acer Predator XB271HU - ASUS VG248QE - QPAD MK-85 (MX-Brown)/Logitech G PRO Wireless - Samsung 960 EVO 250GB, Samsung EVO 860 500GB, SanDisk Ultra II 480GB, Crucial MX500 1TB - Steelseries Arctic 5 - Corsair 750D - Custom water loop
Beror väll på om den är låst eller inte? Asså låst till ett abonemang som tex telie telenor tele 3 osv?
that swedish learning curve xD
i think the AT&T works not 100% though
Citera mig för svar :D
- Årets Citat: Vattenulf -
"Pumpen snurrar inte den står stilla i botten på chassit. Om den hade snurrat skulle slangarna blivit vridna så det vill man ju inte."
