Water cooling for RTX 2080i?
Okt 2018
Which Water cooling would you recommend for GeForce 2080i during overclocking?
Clarified thread title / Moderator
Moderator
Jul 2017
Hello, @livedon and welcome to Sweclockers!
In order for the forum to be easy to navigate, and to get good responses on the forum, it is important that posts are placed in the correct subforum and with a descriptive title. I have therefore moved the post into the appropriate forum, and clarified your title.
However, I don't believe there is a GPU named "GeForce 2080i". There is the Geforce RTX 2080 and the Geforce RTX 2080 Ti. Which one do you mean?
Also, what type of water cooler you can use will depend on the specific partner model of graphics card you have chosen.
I would invite you to post back with a few more details, because as it is right now, your question is not easy to answer.
Regards,
pv2b (Forum moderator)
För bäst hjälp, försök att svara på alla frågor som ställs i ett inlägg. Då slipper vi fråga om samma sak fler gånger, och du får hjälp snabbare. :-)
