Samsung 860 500gb not allowing create drive or extend drive?
Hej! So once upon a time i made my SSD into 2 partitions. I then decided to delete the 2nd smaller partition in order to combine it into one whole. Now i am stuck.
I cannot extend the 1st partition(not enough space)
or
Allocate a drive to the second smaller one that i deleted(the size of the extent is less than the minimum)
Nothing in Samsungs Magician software gives me any "reset to factory" function.
photo of disk manager
Any help would be grand.
>>Evolv ATX Glass- 8700k - Asus Apex MB - EVGA 3080 10GB FTW ULTRA- WD 750N 1Tb -Samsung 860 500Gb (2st)- WD red 3tb- Asus PG279Q - Hardware labs Gts X-flow 420+280 - Aquacomputer 6LT+D5 & EK vattenblocks - Ifi Zen DAC- Sundara - Corsair SP2500 >>Synology 213j o WD red 3tb
Skrivet av reeson:
or
https://www.geeksforgeeks.org/difference-between-basic-disk-a...
Start with converting it to Basic from Dynamic.
https://docs.microsoft.com/en-us/windows-server/storage/disk-...
@ToddTheOdd Thanks for your reply. Both partitions were deleted and unallocated. Have changed to Basic. Alas the problem presists?
Try again with the program DiskGenius. It does have a merge function.
| Ryzen 3800XT | Corsair LPX 32GB | B550 Aorus Elite v2 | GTX 970 | Samsung 970 Evo | CM Masterbox 520 | RM750x | Windows 7
| Ryzen 2700 | Corsair LPX 16GB | Prime B450-Plus | GT 1030 | Samsung 970 Evo | Kolink Observatory | RM750x | EndeavourOS
| JDS Labs Atom | Khadas Tone Board | Fostex TX-X00 & HIFIMAN HE4XX |
The free edition does not allow "Change to Basic". But after deleting the previous partitions i clicked on quick partition and it managed to create a partition that included the whole disk minus a new MDR table. Thanks for your help!!
