MODERKORT: ASUS Prime Z790 [] CPU: 13600K [] GPU: Gigabyte RTX 4080 Eagle OC [] RAM: Kingston Fury Beast 32 GB DDR5 [] LAGRING: Kingston Fury Renegade NVMe SSD Gen 4 2TB [] KYLNING: Corsair iCUE H150i RGB Pro XT [] PSU: Corsair AX860i platinum [] BILDSKÄRM: LG 34GP950G 180hz [] CHASSI: Fractal Design Define 7
LAPTOP: Apple MacBook M1 2020 [] SPELKONSOL: Microsoft Xbox Series X FILSERVER: 14 TB lagring.
BRA guide för n00b som ska bygga dator själv för första gången...
|< #1 Fisken i valnötslådan kände lusten att suga tomater på arbetet >|
|< #2 Bögens lutfisk suger torrt i skafferiet >|
Dator: Antec 1080, 430w:Msi k8n neo nForce3: 2x512KIngston ValueR 3200 400mhz: AMd 64 3200+(clawhammer) @ 3600+: X800XT PE 520/560: 1x seagate 160gb SATA 7200rpm, 1x seagate 200gb SATA 7200rpm: Soundblaster Audigy2 ZS: Razer Diamondback Plasma och 1 Magma +Hyperglides: Logitech Media keyboard: Sennheiser pc 160: Samsung 959NF 19" @ 1280x1024 100HZ
7800X3D - 4090 FE
[Amd 2500+ @ 3200+] ¤ [Abit NF7] ¤ [1024 ddr @ 400 mHz] ¤ [Radeon 9600 pro] ¤ [Maxtor diamond max 160Gb] ¤ [Lain li PC 60]
http://forum.sweclockers.com/showthread.php?s=&postid=3916792...
Aspire x-cruiser 400w, Lanparty ultra-d S939, Athlon 64 venice 3000+@2400mhz, Corsair XMS pro, Saphire X800 GTO, Seagate 160gb, Musketeer II, viewsonic g90f+ 19"
Helt enkelt det "bäääääääääääästa" systemet
=-Datorn:Athlon 64 2249mhz (9x250) s939(Primestabil 3 dygn), Abit KN8 Ultra Pci-e, 2x512 mb Kingston PC-3200 ,Powercolor X800GTO 16, Seagate 200Gb+250Gb+250Gb, Antec Lanboy,Zalman Cnps 7700 & NB47J, Seasonic S12 430w=-=Soffleksakerna:Viewpia 32" LCD (Mördad Av Postverket),Xbox 360 Pe, Dilog DT355-=
:: MAIN :: Asrock P67 Extreme4 :: 2500K :: 970 GTX :: HP W2207 :: Corsair 16GB :: TRUE :: Samsung 850 :: Logitech diNovo Edge :: HTPC :: ION :: Intel X-25 G2 :: Array R2 :: Samsung F4 ::
|| SWECLOCKERS.COM || oskar@sweclockers.com || OSkar000.se || Fototråden ||
|| Gundeman || Bartonofix || GundemanX2 || Obelinux || Nexofix || Filofix || Ircofix ||
|| Tillse att hjärnan är inkopplad innan fingrarna vidrör tangentbordet ||
|| D300 | D700 | 24/2,8 | 28/2,8 | 35/2 | 50/1,8 | 55/2,8 | 85/1,8 | 105/2,5 | 200/4 | 300/4,5 | 10-20 | 24-70/2,8 | 75-150/3,5 | 80-200/2,8 ||
Bomba.nu
i7 950 @ 4ghz | Asus P6X58D-E | Corsair 6GB 1600MHz XMS3 | Asus GTX 770 OC | 50 TB SSD
- If you don't change direction, you may end up where you're heading
Macbook
