Allt från Computex 2023
Problem med FTP-server(folk kan inte ansluta korrekt)
AKTIV ----------------------------- Status: Connecting to exet-upload.mine.nu:* ... Status: Connected with exet-upload.mine.nu:*. Waiting for welcome message... Response: 220 exet-upload.mine.nu FTP server (Version 6.00LS) ready. Command: USER **** Response: 331 Password required for *****. Command: PASS ****** Response: 230 User ***** logged in. Command: FEAT Response: 500 FEAT: command not understood. Command: SYST Response: 215 UNIX Type: L8 Version: BSD-199506 Status: Connected Status: Retrieving directory listing... Command: PWD Response: 257 "/usr/home/******" is current directory. Command: TYPE A Response: 200 Type set to A. Command: PORT 192,168,0,37,204,199 Response: 200 PORT command successful. Command: LIST Response: 425 Can't build data connection: Operation timed out. Error: Could not retrieve directory listing PASSIV ---------------------------- Status: Connecting to exet-upload.mine.nu:* ... Status: Connected with exet-upload.mine.nu:*. Waiting for welcome message... Response: 220 exet-upload.mine.nu FTP server (Version 6.00LS) ready. Command: USER ******* Response: 331 Password required for ******. Command: PASS ****** Response: 230 User ****** logged in. Command: FEAT Response: 500 FEAT: command not understood. Command: SYST Response: 215 UNIX Type: L8 Version: BSD-199506 Status: Connected Status: Retrieving directory listing... Command: PWD Response: 257 "/usr/home/******" is current directory. Command: TYPE A Response: 200 Type set to A. Command: PASV Response: 227 Entering Passive Mode (192,168,0,3,233,121) Command: LIST Error: Transfer channel can't be opened. Reason: Anslutningsförsöket misslyckades eftersom den anslutna datorn inte svarade inom en viss tid eller på grund av att den etablerade anslutningen till värddatorn inte längre fungerar. Error: Could not retrieve directory listing Command: TYPE I
Ja som ni ser vill den inte funka som den ska, jag har öppnat porten som används av ftp-servern i min router, men det funkar fortfarande inte för utomstående att komma in ordentligt.
kör standard ftp-demonen som följer med FreeBSDv6.0
Asus Maximus II formula, E8400 @ 3.9GHz, 4GB Dominator DDR2, Radeon HD4850.
Att PORT inte fungerar är för att de sitter bakom en router med felkonfigurerad ftp-klient,
Att PASV inte fungerar är för att du sitter bakom en router med felkonfigurerad ftp-server.
http://forum.sweclockers.com/showthread.php?s=&postid=6147578...
I have free will but I choose to oscillate
Tackar så mycket, orignal-servern hade ju tyvär inte att man kunde ställa in passiva portar, eller sitt "riktiga" ip, men bytte till proFTPD där det gick bra, tackar för hjälpen.
Yes... somsagt.. ställ in rätt MasqueradeAddress och PassivePorts så funkar det
Lösningar föder nya problem tyvär.
Det är så att nu när jag ansluter till min ftp-server, så väntar klienten på ett "welcome message" i kanske 10 sekunder innan den fortsätter vidare(var inte sådär med ftpd), jag har googlat efter lösningar men inte hittat något.
Och jag har inte hittat någon config-inställning som gör så man kan stänga av welcome message helt.
Så vad är lösningen? För det blir olidligt när man ska föra över 10 små filer och på vänta 10 sekunder mellan varje filöverföring.
=EDIT
Inget med welcome message att göra.
IdentLookups off
UseReverseDNS off
Löste problemet.
I pure-ftpd får man ange att man vill köra utan welcome messages under kompileringen med en flagga som heter typ --no-banner. Skulle kunna vara något liknande för proftpd. Lär ju stå i dokumentationen om inte annat.
Nu med kortare användarnamn, men fortfarande bedövande långa inlägg.
