What cable to connect a sub from 1 output to 2 rca (right & left/lfe)?
Hello, quick question.
I'm wondering how I would connect a Klipsch R-115SW sub which have 2 rca (right & left/lfe) to an kef ls50 w2 which only have one sub output.
Am i supposed to use an example an 1 rca to 2 rca cable or just 1 rca to 1 rca to the lfe input?
Any difference between them?
Rekordmedlem
The sub is mono but the KEFs have individual sub outputs so the best would be a mono cable from each top speaker to the corresponding input on the sub.
Skrivet av mrqaffe:
The kefs have a setting to either send both signals to both speaker outputs or only send right speaker signal to right output (Mono/stereo) so I don't that specifically matters, if I understood correctly.
Rekordmedlem
Skrivet av mambans:
https://i.imgur.com/pKnII21.jpg
Set it to mono and use a single chanel cable, it will be the cheapest option.
