EK Water Blocks presenterar vattenblock för Geforce RTX 3000-serien
Phanteks P400s | Asus B-350 Strix |Ryzen 5800X
G.skill 16GB 3.6Ghz CL16 Trident Z RGB | FD Celsius S36
Samsung 960EVO 500GB |Corsair RM750x | Asus Vega 56 Strix
Corsair Obsidian 1000D* Corsair AX1600i* MSI X670E Tomahawk* AMD 7800X3D* 32GB G-Skill DDR5 6000Mhz* Asus RTX 4090* Corsair MP600 1TB* Samsung 980 Pro 1TB
9800X3D | 7900XTX Merc 310 Alphacool | ASUS B650E-F | G.Skill 6000Mhz 32GB CL30 | SN850X | EK Quantum custom loop | Be Quiet 900 Dremel Edition | ASUS Xonar STX + Sennheiser HD650 | Corsair RM1000x | Monitor: LG C2 42 | PS5 Pro | Nintendo Switch 2 | TV: LG C1 65
If it can't run Crisys its a calculater
The New Build The Torrent 2,0
9950X3D | 5080
Låda thermaltake view 91 M-kort ASUS X399 ROG Zenith Extreme CPU AMD Ryzen Threadripper 1920X 3.5 GHz Kylning Hemma byggd vattenkylning 2 x 480mm + 1 x 420mm radiatorer Minne 8 X 16Gb DDR4 HD SSD 240GB OCZ Trion 100 Grafik Gigabyte Geforce RTX 3080 10GB GAMING OC WATERFORCE WB AGG Corsair RM 1000w 80+ Gold Skärm ASUS 43" ROG Strix XG438QR 4K VA HDR 120 Hz
Galleriet: Dynamic Black Chassi: Lian-Li O11 Dynamic & custom loop CPU: AMD Ryzen 5600X RAM: GSkill Trident Z 32GB Moderkort: Gigabyte X570S Auros Master GPU: EVGA RTX 3080 XC3 SSD: Samsung 970 EVO 500GB PSU: Seasonic PX850
Wasserkühlung::5900X::ASSrock X570 TB3::2x8 Ballistix 3000@3800::6800Nitro+
Vilken leksak>> CH341-biosprogrammerare
Ryzen 7 7800X3D | RTX 3070 | 2x32GB DDR5-5600 | B650M Pro RS WiFi
Define R5 Blackout | Noctua NH-U14S | EVGA G2 SuperNOVA 850W
G502 Proteus Spectrum | Vortex Pok3r RGB
Senast redigerat
AMD Ryzen 9800X3D (Arctic Liquid Freezer III 280) | MSI RTX 4090 Gaming Trio | 64 GB DDR5-6000 CL36 | ASUS ROG B650E-I | Asus Loki 850 W | Cooler Master NR200P
Senast redigerat
CPU : 12900KS GPU : 3090 Strix OC RAM : G.Skill 32GB 6600MHz 34-40-40-105SSD : 2st SN850 1TB Bildskärm 1: Strix PG279Q 1440p@165Hz G-SYNC Bildskärm 2: Asus VG27AQ 27" 1440p@165Hz Bildskärm 3: Asus VG27AQ 27" 1440p@165Hz Vattenkylning CPU,GPU och RAM, 3*360 rad
