Guide: Sänkt spänning på Geforce RTX 3080 för markant bättre energieffektivitet
Senast redigerat
If you follow the herd you are going to have to step through a lot of manure. Have the courage to trust in yourself and follow your own path.
AMD Ryzen 5 9600X, 32GB@6000MHz DDR5 & Nvidia RTX 5070
Senast redigerat
Intel® Core i7-13700K @ 5.7/5.6GHz | ASRock Z690 Extreme | G.Skill Trident Z 32GB @ DDR4-3400 CL14 | Samsung EVO series M.2 + Sata SSDs 2TB | Intel Arc B580 | SuperFlower Titanium 1000W | Gigabyte M32Q 32"/1440p 165Hz | Arctic Freezer II 360 AIO | Phanteks P500A D-RGB
Core i9 12900K | RTX 3090 FE | Odyssey G80SD |
Senast redigerat
"Företagsboendeförmedlare" | Min Überkill Dator: Processor: Intel Pentium P5 66 Mhz OC | Moderkort: ASRock P4I65G | Minnen: 2st Samsung 128MB PC133 | Grafikkort: Canopus GeForce 256 DDR | Lagring: IBM 350 4,4 MB | Operativsystem: DOS/360 | Chassi: Mercury Full-Tower ATX Chassis |
Ryzen 7600X - Geforce RTX 4080 - Custom Loop - Samsung 34" Ultra Wide
Intel i7 9700K - Radeon VII
Lightsaber - Black armour - and balls!
Jobbdator: Macbook Pro 16" | M4 Pro | 24GB RAM | 1TB Lagring
Asus ROG STRIX B550-F / Ryzen 5800X3D / 48 GB 3200 MHz CL14 / Asus TUF 3080 OC / WD SN850 1 TB, Kingston NV1 2 TB + NAS / Corsair RM650x V3 / Acer XB271HU (1440p165) / LG C1 55"
NAS: 6700K/16GB/Debian+ZFS | Backup (offsite): 9600K/16GB/Debian+ZFS
AMD 9800X3D - Corsair 32GB 6000 CL30- Gigabyte B650 Aorus Elite - Inno3D 4090 - Intel 900p - CaseLabs SMA8 - LG 42C2 - Asus Loki 1000W SFX-L - Aquaero 6 - Vattenkyld - Steam Deck LCD 1TB
CPU: i7- 13700KF + Corsair iCUE Titan 280 RX || GPU: 5080 TUF OC
MoBo: Gigabyte Gaming X AX Z790 || Ram 32GB G.Skill Trident Z 6600mhz
Chassi: Corsair Obsidian 500D PSU: Corsair RMX 850
Skärm 1: AGON AG271QG 1440p 165hz Skärm 2: LG C2
i9 10980XE | 128 GB DDR4-3600 | ASUS X299 WS PRO | RTX 5080 Founders Edition
R7 5700X | 64 GB DDR4-3200 | Gigabyte B550 Gaming X V2 | RTX 2080 Ti Founders Edition
| 9800X3D @5.4GHz | 9070 XT @3300 MHz | DDR5 @6400 MHz | Asus X870-P | Samsung 9100 PRO M2 | Corsair RM750x | MSI MAG 32" OLED | FrDesign R7 | Soundblaster AE-5 |
5700X3D | ASUS X470-F | 32GB RAM | RTX 5070 Ti
Custom SweC - Optimerar utseendet på Sweclockers. 21 Aug : v0.6.0 Nu kan du dimra bilder på SweC!
Installera Custom SweC UserCSS
Lagers tips: Mappa om framåt-knappen på musen till Home-knappen! Du kan inte leva utan det sedan!
Gaming: MSI MAG X570 TOMAHAWK WIFI | AMD Ryzen 9 5900X | ASUS Prime 9070 XT 16GB | Corsair Vengeance LPX Black 32GB 3200 MHz | Corsair RM850x V2 | Sabrent 2TB Rocket Nvme PCIe 4.0 | FD Define S | LG 27GP850 | LG 48C1
14900KF--Apex Encore--RTX 4090--G.Skill 2x24GB DDR5-8000--Dynamic Evo XL
12900K--Asrock Z790i--2X16GB DDR5 6000
Ljud: Lewitt Connect 6--Shure SM7B
Corsair Obsidian 1000D* Corsair AX1600i* MSI X670E Tomahawk* AMD 7800X3D* 32GB G-Skill DDR5 6000Mhz* Asus RTX 4090* Corsair MP600 1TB* Samsung 980 Pro 1TB
Lian-Li Tu150 (fläktmoddad) w Corsair SF750 Platinum SFX / Asus Strix B550-i Itx / Ryzen 5600x @ 4.92.. Scythe Fuma 2 / Crucial Ballistix 2x16 3600@4000 / WD Black SN850 NVME + Kingston A2000 NVME / MSI Radeon RX 6800 referens / 2x120mm Noctua NF-A12x15 golv. 2x120mm Noctua NF A12x25 In och Utblås. Fläktmod tak 1x140mm Noctua NF A14 utlblås via kammare baktill. Samsung 34" c34j791 3440x1440.
